onehundred80
In an earlier post you said that you did not get a fault code and now you say you cleared the fault codes, which is correct?
If a code was set what was it?
Until last night I had no code. I should've ran it before I worked my rcm but I disconnected my battery before I started n then repaired solder points therefore I may never know what the code that got set was unless it's stored somehow
