Old Dec 9, 2015 | 10:21 AM
onehundred80
Default Re: Completey flustered
Originally Posted by tropixcale
Until last night I had no code. I should've ran it before I worked my rcm but I disconnected my battery before I started n then repaired solder points therefore I may never know what the code that got set was unless it's stored somehow
Disconnecting the battery does not reset the code if I recall correctly, disconnecting the battery actually sets new codes which are to do with the pollution system, and they can only be reset by driving the car for some distance under various conditions. You would not pass any pollution test until that is done. The pollution codes can not be read on some readers and do not set the CE light.
Run a check on the code(s) it should still be there.
