Re: S.C. - Clutch Plate Pulley Assembly
Fla_Xfire_SRT
Suggestions? I did see the info on the srt6comsite and decided not to mess with mother nature and return it to stock. I was confused on the outcome of the thread where a dogbone part or rivet failed due to friction and heat leading to metal fatigue on the Karmann unit. I also read of a hood repair..ouch..mine only went as deep as the insulation got torn. I'm informed now, thanks to this forum and its knowledgeable members about the shield info. I also copied the info on the MB intercooler replacement, while I'm in there. Assembling the total parts list for this job is not an easy task. BTW, current stealership price for the "electric clutch coupling assembly " as they called it is $ 1735.00. wow!
Update: I found it for close to 1200.00 plus the tensioner under 100.
