Old Dec 13, 2015 | 07:31 AM
onehundred80
Default Re: Solved the Mystery No Start, now it's the Mystery headlights on, no break lights.
Originally Posted by ReignMan
Hello all,
It has been forever. Turns out that the RCM was fine, feel free to fix whatever joints you see that need fixing. I found out that my light system was out due to a faulty pigtail on my left rear tail light/ brake light, connection which caused the Bas/Esp sensor to display on deck. I ordered a new pigtail off of Ebay for about 12 dollars US.
Also the mystery no start could easily be caused by the wire that connects to the crankshaft position sensor, so the car ended up shutting off again. It ended up being the connectors from the said wire to create a faulty connection until I bent them back into proper position. The CSPS was fixed after that, and amazingly, that solved all my problems.
That is great news, simple faults that caused you a lot of misery all solved for just a little money.
