Old Dec 13, 2015 | 05:54 PM
amx1397
Default Re: 3.46 diff. for the crossfire
[QUOTE=pioneer4x4;854558]I'm not sure I understand what you are looking for? Engine doesn't change rpm, and also you need to specify what gear you are looking for.
And with a 6sp, just multiply the 60 speed by 1.33 and that will be rpm at 80, assuming you are in the same gear. With auto, there may be slip if the converter isn't locked, but assuming it is, all straight math, but you need to specify which gear.[/QUOTE
no multiplying I need real numbers. each car's rpm above may or may not be different that is why i ask for real time 60,,70 ,,and 80 mph /rpm and if u are cruising at 60 you should be in high gear for auto that would be 5th gear for the 6 speed that would be 6 gear ,,hope this helps. jim
