GraphiteGhost
If you go the +12 trigger on startup, there is a hot right at the panel where the switches (spoiler switch) are. Does the spoiler control (switch) a +12 or is it a signal to/from the BCM? If +12, you can use that 12 supplying the cigg lighter to a relay, as it powers on when car starts. you can then use the spoiler switch to 'override' that sequence/relay if the need arises (ultra minimum of parts/wiring if done right).
Thanks for the info, I've now installed it and I went with fitting a micro switch in the door as a trigger because I really wanted to be able to raise and lower it with the remote locking.
Here's my thread of it all installed with pics and videos:
https://www.crossfireforum.org/forum...ics-video.html
