Old Dec 16, 2015 | 10:38 AM
amx1397
Default re: Information on our differntial
how to remove and reinstall your diff.
1 drain the oil
2 take all the arms loose, not the lower control arm,
3. take the brake caliper off the rotor, tie it up.
4 with the shock loose from the lower control arm
5 remove the axle nut at the rotor
6 pull the rotor down and to the left or right so the axle will come out of the rotor
7 remove the bolts on the driveshaft center bearing let it float
8 remove the bolts on the driveshaft flex coupling, pry the drive shaft out of the diff.
8 put a brace under the diff or have someone hold it up as you remove the two bolts at
the rear of the diff, remove the bolt at the front of the diff.
9 remove the diff.
10 reverse the steps to reinstall the diff. use only the oil recommended by unatrx
