Old Dec 17, 2015 | 03:16 PM
ala_xfire
Default Re: New Guy, Old problem
Originally Posted by Mark SRT6
Gang, I figured out the problem. Ironically one night out of "frustration" I slapped the key fob on my leg hard. Put key in and it started right away. Subsequently each time it started and shut off I smacked the fob and it started every time. I checked battery tabs to amke certain they were tight, yes. New battery, same outcome. Slap it and it worked fine. Got new key from Needs and it is perfect. No problem since. The security id obviously wasn't working without being jarred so it would shut down. Thanks fo everyones help.
The security chip thingey in the key fob is not powered, so replacing the batteries would have no effect, however if it came loose inside the fob and migrated away from the sensor ring at the ignition switch, this could be the problem.
In your spare time, take the old fob apart and see if this is what happened.
https://www.crossfireforum.org/forum...ey-rebuild.pdf
