Re: S.C. - Clutch Plate Pulley Assembly
The cut in the air supply aluminum tubing from the auxillary air pump , my welder said couldn't be filled, so, I found a piece of heater hose that is tight and has almost the same bend in it and I am hoping to extend it across the cut and clamp it temporarily until I get the correct part to replace it with. I'll look for a SLK32 vin to try the link for parts 180.
