Thread: Airbag and Horn
Old Dec 19, 2015 | 12:37 PM
mariontr's Avatar
mariontr
Default Re: Airbag and Horn
I would doubt that the air bag and horn are connected in any way, why would they be?
Probably a fuse in the horn circuit, I think you are being taken advantage of. The horn has one fuse under the hood which I assume is OK as the other items on the circuit are working you say.
There is also a fuse and a relay in the Relay Control Module under the hood and this is where I suspect the trouble lies.
Did it suddenly stop working? What is the story behind the problem.
They said they fixed then it works for a day then it does not. It started about two weeks ago was working then failed. Took it to the dealership they fixed they said had some corrosion on the contacts for the horn. Worked for a day as I staed above, took it back a week or sao ago that's when they said it was the airbag.
