Thread: Airbag and Horn
Old Dec 19, 2015 | 12:50 PM
onehundred80
Default Re: Airbag and Horn
Originally Posted by mariontr
They said they fixed then it works for a day then it does not. It started about two weeks ago was working then failed. Took it to the dealership they fixed they said had some corrosion on the contacts for the horn. Worked for a day as I staed above, took it back a week or sao ago that's when they said it was the airbag.
In a previous post the clock spring was mentioned, the clock spring could be the problem I guess but not the air bag as the dealer says.
Anyhow, have you looked at the Relay Control Module (RCM)?
There is a relay and a fuse in there that operates the horn. Maybe the contacts on the relay are burnt or damage somehow. Maybe the horn relay needs replacing, if the contacts on that are damaged they only get worse.
They say corrosion on the horn, what do they mean? Contacts on the wires, amazing how the air bag is not mentioned or did they play with that?
Do you use your horn a lot? I doubt if I have used mine more than a dozen times in four years.
Some of the numbers I assign to the fuses may be wrong. I'll have to fix it some time.
