Re: Oil can and displays 'hi'
You can see the info if you do this too.
CHECKING ENGINE OIL LEVEL
A sensor in the oil pan allows oil level to be checked
without opening the hood. It provides an accurate measurement
of oil level, whereas the low engine oil level
indicator warns that oil level is definitely too low. With
the vehicle parked on a level surface, the engine is
warmed up and shut off for approximately five minutes.
When the ignition switch is turned to the ON/RUN
position, an ISO oil level icon appears in the trip odometer
window and a “clock” icon in the cumulative odometer
display. Pressing the **** to the left of the speedometer
twice displays one of the following messages:
˛ OK
˛ -1.0 Q (-1.0L)
˛ -1.5 Q (-1.5L)
˛ -2.0 Q (-2.0L)
˛ HI
