Old Dec 24, 2015 | 07:48 PM
onehundred80
Default Re: Only third brake light working
Originally Posted by dobermann
Hi guys,
A little while ago my brake lights stopped working. I'm not sure when but at least 2 months ago a forum member told me on the DVP in Toronto.
I've been using the car again more so I want to fix the issue. Based on reading this forum and searching in general I think it's the turn signal switch. The lights work to signal but not when the brake pedal is pressed.
If this is the issue is there a good way to confirm it?
Do I need to disconnect the airbag in order to replace the turn signal switch?
I've watched some how to videos on other cars and if that's the issue it looks very easy to fix but likely something a mechanic would take me to the cleaners over.
If anyone knows about this problem I'd appreciate any advice. The BAS/ESP light is on but it has been on since I replace the steering dampner years ago.
The BAS/ESP light is a symptom of a failed brake switch or brake solenoid among others I believe.
Maybe your light has been out for years.
