PEOPLE, IT WON'T HURT IF YOU CHECK OUT THIS THREAD:
https://www.crossfireforum.org/forum...5528#post85528
I TOO HAD THIS PROBLEM... MINE WAS RELATED TO THE TRANNY...
1ST PROBLEM:
HESITATION... THE ENGINE SEEMED TO BOG OUT.
2ND PROBLEM:
TRANNY STARTED TO BUCK GOING FROM 2ND TO 3 GEARS (I HAVE AUTOSTICK) WATCH YOUR TACH... I HAD PROBLEMS AT THE 1,500-1,800 RPM RANGE.
3RD PROBLEM:
AND THIS WAS STRANGE... THE REAR WHEEL(S) STARTED TO RUMBLE AS IF I WAS DRIVING OVER SPEED STRIPS (LIKE THE ONES ON THE SHOULDER OF THE HIGHWAY OR THE ONES YOU RIDE OVER APPROACHING A TOLL BOOTH)... THEY CALL IT "DRONING"!
IF YOUR TRANNY STARTS TO BUCK, IT DOES GET WORSE... MAKE SURE WHEN YOU APPROACH A RED LIGHT OR A STOP, DROP THE TRANNY INTO NEUTRAL AS THE CAR WILL B U C K FORWARD... SHARPLY... WITHOUT WARNING AND IF THERE IS A PEDESTRIAN OR EVEN A CAR IN FRONT, IT WILL LUNGE FORWARD EVEN THOUGH YOUR FOOT IS ON BRAKE...
SOMETIMES THE LUNGE FELT AS IF SOMEONE HIT ME FROM THE REAR!!!
SO DROP THE TRANNY IN NEUTRAL WHEN YOU APPROACH A RED OR STOP SIGN...
AND GO TO THAT POST ABOVE AND PRINTOUT WHAT I PROVIDED THERE... IT MAY HELP YOU AND YOUR DEALER.
HAPPY 4TH!!!
J
BUT THE ROAD WAS SMOOTH!!!
