Old Dec 26, 2015 | 11:06 PM
onehundred80
Default Re: Engine cranks; no compression?
Originally Posted by cdrance
Thanks to all responding. Cam shaft timing marks line up horizontally with cam bolt and with copper links, but the crank should be at 40 degrees after TDC; its at 60 (onehundred80). I haven't take off the timing chain cover yet, to confirm, but that's why I think it jumped a tooth at the crank sprocket. There's 120K mile on the engine (ala_xfire). I have never run low on oil, in the 4 years I've owned the car. It was running OK.
The cam marks are not horizontal at the 40 degree point. In the drawing above you can se that if the crankshaft was turned so that they were horizontal then the 40 degree mark would have gone by the pointer.
The crankshaft key is at the top when the 40 degree mark lines up. You should be able to see the slot in the pulley at the top.
