Old Dec 28, 2015 | 12:29 PM
dedwards0323
Default Re: Climate Control Fan Speed Fix
I get the pdf fine, but I see three of the same pdf in your post, it is the links in the pdf that do not work.
Is it my iPad that is screwing me up? I'll try on my PC.
The PDF has 2 links embedded in the document that refer to other sections of the XFire Shop Manual I've got on CD. And those links won't work without the CD available. That's probably causing the issue you're seeing on your iPad. Causes an issue on my PC, too. Maybe I need to change these to text only. Let me know.
Hope this helps,
