Old Dec 28, 2015 | 01:51 PM
onehundred80
Default Re: Climate Control Fan Speed Fix
The PDF has 2 links embedded in the document that refer to other sections of the XFire Shop Manual I've got on CD. And those links won't work without the CD available. That's probably causing the issue you're seeing on your iPad. Causes an issue on my PC, too. Maybe I need to change these to text only. Let me know.
Hope this helps,
Aha, that makes it clear, I have the CD but I never use it.
But it does not explain the three identical pdf's in your post. I have had unexplainable things happen to my posts though. The nature of the beast.
I would add the other info as PDFs that would let everyone see it, or just add the info that can be found here in the How To section.
