Old Dec 30, 2015 | 12:05 PM
Padgett's Avatar
Padgett
Default Re: Can you fit 4 x 19" wheels without tyres in a coupe?
Haven't tried but why would it set a light, there is no airbag in the seat ? Connections are just for the heater and power seat motors.
From 2004 FSM page 23-202:
1. Move the seat (1) all the way back to its lock position.
2. Pull the plastic front covering (3) from the seat tracks.
3. Remove the two front seat track bolts (2)
4.. Move the seat all the way forward to its lock position.
5. Remove the bolt (2) on the seat track for the seat belt mounting.
6. Remove the belt end from the seat adjuster.
7. Remove the rear two bolts (1) attaching the seat track to the floor.
8. Disconnect the electrical connectors for the seat heater and the electrical seat adjustment.
9. Move the seat backward, lift up and then remove from the vehicle.
