Old Jan 1, 2016 | 02:08 PM
onehundred80
Default Re: 2005 Crossfire won't start
Originally Posted by twboyle
Battery terminals are clean, no sign of corrosion on terminals or where the cable grounds to the frame. Would the RCM cause the rear spoiler to raise and stay? Tried the console button and won't lower it.
Lights stay well lit no fade when on and try to start.
You may have battery problems not enough strength in the battery causes problems, the spoiler raising is one of the symptoms. You may need a new battery.
The RCM can cause the same symptoms you are getting but I would not expect the fault to occur coincidentally after the car has sat for two months.
The bulbs would not dim if the power is not being taken from them to power something else, so I assume your starting circuit has no power going to it.
The lights may not be at full strength anyway, hard to see the lack of light in the day time if that is what you mean.
