onehundred80
Is this part damaged? If it leaks it may be because the window does not seal
against the seal properly. The window can be moved against the seal, up and inward if required and it would be a lot easier than fitting a new seal which may not be required.
The actual seal is somewhat damaged by the leaking area. It needs replacing. Also -- for future reference, how would I go about adjusting my window? Via inside the door panel?
