Old Jan 5, 2016 | 11:12 AM
  #4279 (permalink)
onehundred80
Originally Posted by pioneer4x4
I was greeted with this today.
1-5-2016
Tripped my tire pressure light, they looked fine, I bet the light will be off when I go home today.
Also for some dammned german reason, you can't use the high setting on heated seats when it is actually cold out. Both red LEDs flicker when pushed, on both seats. After a few minutes on LOW, I could select HIGH. I'll read up on it.
Just because the light goes out does not mean the tires are at the correct pressure. For the light to come on it means that they were not at the correct pressure when the temperature was a bit higher.
That's what I believe anyway.
