onehundred80
Just because the light goes out does not mean the tires are at the correct pressure. For the light to come on it means that they were not at the correct pressure when the temperature was a bit higher.
That's what I believe anyway.
I can mean many things unfortunately. I am assuming (with high confidence) that one or more of my tires were ever so slightly below threshold, and need bumped up for when it is 7 friggin degrees outside. Same thing happened the first time it was in the 20s. One other thing with the age of these cars is the 11-12 year old battery in the wheel transmitter could be weak enough to not work when frigid. Either way, I didn't feel like checking the pressure this morning, when I was sure that at worst they were a smidge low. Also the flashing lights on the seat heaters may be normal low startup voltage warning, not sure. All from the dammned cold, I'm not fully ready for this...
https://www.crossfireforum.org/forum...s/icon_sad.gif
