pioneer4x4
Also for some dammned german reason, you can't use the high setting on heated seats when it is actually cold out. Both red LEDs flicker when pushed, on both seats. After a few minutes on LOW, I could select HIGH. I'll read up on it.
I found a good thread and pasted this part. Here is the whole thread too.
Not the usual Seat Htr problem
Hey guys . . . according to the Crossfire Specialist Student Reference Book . . . I quote on the Heated Seats
" The heaters may automatically switch off due to HIGH electrical system demand or a low battery. When this occurs, one or both indicator lamps blink (depending on selected heating level) until enough voltage is available."
That is why when it is really cold and you start up the car, with a low battery and switching on the rear defrost, you get the blinking lights. I would suggest you let the car run for a bit before hitting the
heater switches ! I don't drive my car in the winter, so have not encountered this issue. . . .however, I did recall reading it . . .
Here's another
This morning I had the blinking problem at 13 degrees. I've had it few times before on cold mornings.
I was thinking that this is caused by an over current draw by the resistive heaters. When too cold they draw too much current, when up to a reasonable temperature all is okay. Usually your butt heats the seat up enough in a few minutes that it works normally.
I thought that each blink was an actual current pulse to the
heater. Having this in mind, I decided to hold the button down to see what would happen.
As I held the high heat button down, I saw that each pulse got a little bit longer. Heaters warming up, resistance going up, current going down? After 25 to 30 pules it stayed on.
