Thread: Mystery wires
Old Jan 11, 2016 | 11:13 PM
onehundred80
Default re: Mystery wires
Originally Posted by crossfiremaniac
OK so my top does not go down and my door locks do not work from the switch on the dash. I went in the trunk to look at the vacuum pump and there are 2 wires that are not connected. A red one and a gray and red one coming from the pump area. I do not see a place to connect these wires to. They have a connector on the end but I do not see a place where they go. Can someone help me? Is this why the vacuum pump is not working? Help please Crossfires are new to me so don't know all that much about them yet. Thank You
I have a spare pump with the four plugs and there are 19 wires that go to the pump.
One long black plug (C2) has 4 wires one of which is a large red/green wire, another square black plug (C4) has 3 wires one of which is grey/red, a white plug with a grey latch (C1) has 5 wires and a rectangular black plug (C3) with a gray latch has 7 wires one of which is red/gray and another brown/red.
They are the only four wires with red in them. The first color is the major wire insulation color and the second color is the stripe on the insulation.
Mine is a coupe harness I think.
The wires you have on the '05 circuits does have a a brown/blue and it goes to the lift gate lock switch. 8W-61-3.
Is that a roadster wire or not??????
I cannot find a red.
The wire colors are known to be different in some cases on the car, differing from the Repair Manuals
