crossfiremaniac
I found that my wire in the trunk went to the trunk light. Now this vacuum pump it does not work. I do not see any water stains on it. What powers this pump and how do I test this pump. I figured out my mystery wires on my own. I am hoping some one on this forum can help me with this pump issue. Is there some sort of diagnostic procedure for this pump? Can some one help me this time or am I on my own again?
If I remember correctly my post before you mentioned you had found where the wire went said that I thought it could be a wire for a light among other things, this was after you got upset with the response you had got.
The Service Manual lists a series of tests to do on the pump.
If you are to get any help I suggest you change the attitude a bit. No one is paid to help you, it is done by Crossfire owners to help fellow Crossfire owners with their problems. Your input with the wire problem gave incorrect wire colors and a blurry picture, hopefully it will be better this time, otherwise your best option will be to throw yourself on the tender mercy of a dealer.
