Old Jan 18, 2016 | 10:11 AM
onehundred80
Default Re: Crossfire roadster, strange ignition problem, please help.
Originally Posted by leemeg99
hi, i have a 2005 drossfire roadster. the problem i am having is when i turn the ignition to start the engine.
When the ignition is in the on position it appears everything functions properly (all roof functions, window defrost), however when i start the car the roof doesnt operate, only the lamp flashes, when moving the windows start to fall and the rear window defrost doesnt light up.
any ideas, thanks
If I was you I would keep this post with the initial post you did on this forum, that way what has been done before can be seen. Otherwise the same hints will be given to you again, this is not productive.
You said the window problem had been solved before and now it appears not to be solved.
