Old Jul 4, 2006 | 07:07 PM
woody's Avatar
woody
Default Re: Today's Dyno Run
Originally Posted by dynamicS
My question is, what would happen with the ECU if the rear wheel diameter was the same size as the front wheels or vise versa? Would this trip a code in the computer and screw up hp output?
That's a valid question. I don't think it is a major issue though as the ECU has to allow a big differential between wheel speeds in normal driving conditions anyway.
great idea, hope it works, but I can't imagine your ABS will work properly. guess you can always restore the front sensors after dyno runs.
Yes, the mod will only be a temporary 'fix' for dyno runs, so it won't matter if the ABS isn't working. I am going to try another dyno run this week if I can get a slot booked.
