Old Jan 18, 2016 | 08:09 PM
Squirrel Crusher's Avatar
Squirrel Crusher
Default Re: Check Engine Light code P0505
Originally Posted by amx1397
they cost around $100 ,,if u don't want sell them here is a add for them
Thermalnator is a unique high temperature shielding gasket which replaces the stock intake manifold gasket. Thermalnator’s cooling properties reduce heat by stopping metal to metal contact between the intake manifold and the engine block. By using a Thermalnator gasket, you will reduce the heat of the air entering your engine, making up to 5% more power. Thermalnator gaskets allow the intake manifold to perform like an intercooler. Because the manifold is no longer heated by the cylinder head, the heat from incoming air can dissipate through the aluminum very rapidly. The basic formula for this is for every 5 degrees F increase in intake air temp, air density is reduced by 1%. The denser the air is, the better the gain in horsepower.
Hey Jim...Who is selling these gaskets? Thanks..Squirrel Crusher
