onehundred80
The clicking solenoid is not a sensor it is a part of the fuel vapor control system and allows fumes to be vented through the throttle body for burning, it is called the EVAP PURGE SOLENOID and I cannot see how it is affected by the alarm problem.
Get the engine error codes read to see what is causing the CEL, I would expect it to be caused by the purge valve problem.
Thanks for the response onehundred80.
Following the PDF I was able to replace the batteries in the siren and haven't had an issue with the alarm since XMAS, great!
After fixing the alarm the engine fault light remains illuminated which was expected. I got the engine fault light diagnosed at a car service place down the road (free of charge which was nice of them) which show the following error codes.
- P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
- P0403 Exhaust Gas Recirculation Circuit Malfunction
- P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
- P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
Which could be caused by the following, looking at the 2004 service manual.
P0403
GR SOLENOID CONTROL CIRCUIT OPEN
EGR SOLENOID CONTROL CIRCUIT SHORT TO GROUND EGR SOLENOID CONTROL CIRCUIT SHORT TO VOLTAGE FUSED ENGINE CONTROL RELAY OUTPUT CIRCUIT OPEN EGR SOLENOID
EGR VALVE
POWERTRAIN CONTROL MODULE
P0412
FUSED ENGINE CONTROL RELAY OUTPUT CIRCUIT OPEN GROUND CIRCUIT OPEN
FUSED ENGINE CONTROL RELAY OUTPUT CIRCUIT SHORTED AIR PUMP SWITCHOVER SOLENOID
P0132
O2 SENSOR SIGNAL CIRCUIT SHORT TO VOLTAGE ENGINE EXHAUST LEAK
O2 SENSOR
P0155
O2 HEATER CONTROL SHORTED TO GROUND
O2 HEATER ELEMENT
P0135
O2 HEATER ELEMENT
The mechanic did reset the codes but the engine fault light turn on again 2 days later.
From what I can tell the car runs fine and doesn't seem to have any issues so at this stage I am not sure where to start but I would like to get it fix and am willing to give repairing it a go.
Looking at the faults above where should I start? I am resourceful and should be able to find my way but would appreciate any advice and will stay updated.
