Old Jan 19, 2016 | 07:40 AM
brandoni's Avatar
brandoni
Default Re: intake gaskets Needswings?
Thank you for that info. Yes the previous owner had a code 3 pull installed and did have TVT do some performance work on the car.
Do you have the contact number for the bolts from needswings? I will keep the spacers for the reason installed. The gasket replacement is so easy I don't mind cutting the cork every few years. You guys are a godsend , thanks again.
