Re: S.C. - Clutch Plate Pulley Assembly
Two-piece shaft collar, 3inch bore, 7/8 wide, will have to work, it's on the way. There will be enough bore diameter to use an old rubber printing blanket between the two to better the grip and protect the grooves when I tighten the collar around the SC pulley. I will have to deal with what I expect to find as a gaulled shaft when I get it off. Wish me luck
