Old Jan 25, 2016 | 08:25 AM
onehundred80
Default Re: Headlamp unit advice needed
Originally Posted by Fozz
Hi,
I've got a problem with the right side headlamp assembly.
The main (high) beam projector housing is out of alignment. Sends the light beam out to the right by about 30 degrees rendering it next to useless.
Can this be fixed or do I have to bite the bullet and get a replacement unit?
Thanks
Attachment 36706
Attachment 36707
Are you sure that the bulb is in correctly?
If the bulb was changed recently then that may be the cause. The alignment can be possibly be set straight but it is something that rarely needs doing unless someone put the bulb in wrong and tried to readjust it. That would show up if the bulb was now set correctly in its seat.
