Old Jan 29, 2016 | 11:18 AM
Franc Rauscher
Default Re: Security Control Module
The number can be found on this ebay search.
That Delphi number you give is a Mercedes number, is that the number on the one in your trunk?
The 193 number means it is a specific Crossfire number and made for the Crossfire, they did not relabel parts for the Crossfire.
The spare one I have is the one used in the search.
If you have water damage then it is probably best to get a pump that has the plugs in the sockets, the plugs get ruined by the water and buying a pump without the plugs may mean a long search for just the plugs and extra cost.
Dave, I was hoping you would see this. Thanks
Well, my first encounter with a Mercedes parts Dept they said NO.
The Pump is fine. It is the relay that is corroded. Circuit board is covered in corrosion.
I will be sealing everything up in plastic and silicone. I just need the part. perhaps another stealership will be more helpful.
The one on E-bay is used. I'm going new if I can source it.
