Old Jan 29, 2016 | 12:07 PM
onehundred80
Default Re: Windshield washer nozzel
Originally Posted by PNA
If a pin doesn't work, which my bet is it won't, you'll need to remover the cowel, remove the nozzle and drill out the inlet from the jet tube connection area. The nozzles are heated and the plastic in the base of the nozzle melts. Once this happens, it won't allow water to flow through the jets. A small drill bit inserted and drilled through the connector will open up the plastic again and allow the fluid to flow through the jets. It's the only way to get them to work again, aside from buying new nozzles (which isn't necessary).
The pin is only to adjust the nozzles and not to clean them. Slime had built up in my lines, almost blocking them completely.
The heaters have been known to melt the plastic as you know.
