Old Jan 29, 2016 | 12:46 PM
onehundred80
Default Re: Security Control Module
Dave, It is a small Black plastic box about 7 mm X 6mm X 3Mm with a six pin connector. Mounted on the floor pan metal just to the right of the pump assy.
The mean the sizes are 70 x 60 x 30 mm, your measurements would make it pretty small.
You mean this module shown mounted behind the pump under the metal shield? It is the anti towing module that sets off the alarm if the car is tilted.
Thank heavens it is not the pump, that part costs 1/10 th. the pump cost. Look at the pump while you are there and test it before you put it all together again. If that got wet maybe the pump got wet as well.
