Re: Another BAS/ESP conundrum
Sussudio
Yes stock everything. I even pulled everything off again last night. There might be belt slippage as I'm seeing a black dust under the engine cover, but the belt shows no signs of wearing and is very taut. I'm at a loss at the moment as I've been searching all over the forum for an answer. I've searched boost leak, vacuum leak, belt slippage bad IC pump. Not sure where to start though.
I am guessing you have a wheel speed sensor that is giving bad signals to the transmission.
Have you checked for codes?
Codes are stored after the light goes out and remain I think until the problem is solved and is either deleted manually or there have been sufficient automatic checks on the system proving there is no problem after x amount of checks.
