onehundred80
The fog light problem is most probably the security pump, open it up and look for damage from water, you should get a hint of trouble if the plastic case looks as it has sat in water.
See here (CLICK) for the problem of water damage and opening the module.
The Foam box around the pump module was damp. Now that we have removed it and things have dried out, the parking lights work fine. The Fog lights also work fine. Only the interior lights are functioning improperly. They do not come off when you close the doors or dim down when the car is started or placed in gear. Is there another relay or relay timer involved?
I'm going to leave things open to thoroughly air out and then remove the rubber plugs as many have done.
Time to take the wing of anyways and re seal it.
Thanks for the help Dave.
