Old Jan 29, 2016 | 03:26 PM
onehundred80
Default Re: Security Control Module
The Foam box around the pump module was damp. Now that we have removed it and things have dried out, the parking lights work fine. The Fog lights also work fine. Only the interior lights are functioning improperly. They do not come off when you close the doors or dim down when the car is started or placed in gear. Is there another relay or relay timer involved?
I'm going to leave things open to thoroughly air out and then remove the rubber plugs as many have done.
Time to take the wing of anyways and re seal it.
Thanks for the help Dave.
I would open up the pump and let it dry inside the house for some time if you have not already done that.
