Old Jan 31, 2016 | 10:29 AM
onehundred80
Default Re: Another BAS/ESP conundrum
Originally Posted by Sussudio
"Little push" as in I pushed it as hard as I could towards the clutch plate. It just wasn't seated properly.
I'm curious though as why would the snap ring allow the pulley to retract back to the clutch plate? If that were the case then the bolt would have slack in it no?
The bolt and washer clamp the inner bearing, there has to be some clearance between the outer bearing thickness and the snap ring. I would have guessed it to be about .003/.006" min/max. If it moved that much it could close the gap to spec.
How tight was the bearing in the pulley? If you just pushed it it could not have been too tight.
If you could push on it and get it to move I would have guessed that the magnet would have done it as it is quite strong.
