Re: Crossfire won't start
BWilson
Hello All,
I am new here but have been following this site for several years and enjoy all of the information and the support everyone gives each other. My problem is my wife 2005 Crossfire failed to start after parking it. I have replaced the Crank Position Sensor with of from the parts store (not a Bosch, Will have to order) and removed the battery cables and it will crank twice and die each time. All of the lights, radio, windows will work. I can here the fuel pump when I turn the key to the start position. With no luck I pulled the RCM board and replaced with a new factory RCM board. The engine will still crank twice and go dead each time. What do I do now? I am lost at this point.
BWilson
The "crank twice and die each time" symptom is very important. I suspect you mean it starts twice then dies. Cranking is just turning to start.
The crank-start-die two times then nothing is a symptom of the SKREEM module not the CPS. To confirm this disconnect the battery then try to start the car. You get crank-start-die two times? If you disconnect the battery again do you get the crank-start-die two times again? If yes SKREEM module.
