Old Feb 2, 2016 | 04:21 PM
kingdavid54's Avatar
kingdavid54
Default Re: Please Allow Me to Vent "turn over"
Originally Posted by KDW4Him
When you describe what your car is doing when you put the key in the start position the proper term is the car is cranking or turning over. When the car starts it is then running.
When some of you say the car cranks but doesn't turn over, that phrase does not register with me. If the motor IS cranking it IS turning over.
I say this because when some of you say the car doesn't turn over you mean the car does not crank yet the rest of you who say the car doesn't turn over you mean it doesn't start. VERY CONFUSING!
So from this point forward we all use similar terms to describe symptoms. Otherwise we have no clue what is going on and we cannot help you.
That is all, venting complete, carry on....
Clearly your obsession with " lexicography " has left you just a tad bit crankey with the issue of rotational vs non-rotational reciprocating mass, maybe this will become an energizing key that will turn over and start an energized engine of conversation that will serve as an alternator to change the charge of the battery of questions that is sure to come that way you will become the regulator.
