Originally Posted by John Webster
It is off when the yellow icon in the middle of the speedometer is constantly lit. The icon will light up when it is on and active (snow, rain or heavy throttle application in 1st or 2nd gears).
The cup holder sucks. The ash tray gets in the way of the shifter too.
The correct tire pressure is 32 psi front, 33 psi rear.
The black **** in the middle of the console controls the side mirrors. The side mirror heaters are activated when you turn on the rear window defroster. The dashboard vents get all the air, if you want defrost or foot heat/cooling you have to close them with the knurled wheels.
Many U.S. spec cars were shipped with the manuals in the pocket under the trunk floor to the right of the centerline. There should be an abbreviated manual in the pocket in the center console.
The tank holds about 16 gallons (97 octane). The low fuel warning light comes on with about 2 gallons left. If you're driving with a heavy foot that means 40 miles.
Have fun, it's fun to drive.
Ok, I am the first to ask, but where do you get 97 octane? I have only ever seen 93 octane and I think there is a Sunoco 94, but 97. Who sells this?
