Old Feb 5, 2016 | 10:32 AM
zip439's Avatar
zip439
Default Re: interior misting problems
Originally Posted by Fla_Xfire_SRT
Well, I noticed this morning...45degrees, very low 20% humidity, that my windows were all fogging up as well on the rescue SRT. I had the heat on at the first red notch and had to switch to defrost and engage the compressor which cleared it up in no time. Feeling that this was temporary, I turned off the compressor when the fogging cleared, but it came right back. I will have to check out those drains under the wiper cowling I suppose, but if I remove that panel, I want to be prepared to change out the batteries on the skreem module while I am in there.
Your experience with fogging is the norm. I get it every morning here in Alabama with the cooler weather up here. You MUST run the A/C when the heater is running or all the windows will fog badly. My under cowl drains are clean as I open the cowl as regular maintenance. It is a good idea to check your's, but it will not effect the fogging; keep your A/C compressor running when the heater is on.
