Old Feb 5, 2016 | 11:14 AM
onehundred80
Default Re: Intake Manifolds & Y-Pipe
Originally Posted by chuK_138
Not at all. The rubber boots are more than adequately pinched against the pipe from the worm clamps holding them on. Plus they have raised lips at the edges. They'll be getting ported and polished inside only.
I was talking about the plenums, they had a finely machined surface on the bottom to clamp against a steel gasket. Looking at the way the SRT machined edges have been rounded a really coarse grit was used when glass beads, walnut shells etc would have been better to use. Whatever was used the machined surfaces should have been suitably masked.
That is my humble opinion, you may disagree.
