kingdavid54
Hey I'm right there with you I just put a set on my car today and I pretty much agree with everything you said except one thing to compensate for the softer side wall I put 37 pounds in the rear and 38 pounds in the front and it handles the corners very well with no slop.
cudaman
Yep, I'm doing the same. Forgot to mention that. I'm running 39 in front and 38 psi rear. The little nuances of the tire can be felt differently less that way, and the KW's take most of the job of handling keeping the tires planted. Still, as you may agree, great bang for the buck. If they don't have longevity, can just get another set at that price. Time will tell as the tread wears down, but when new, these things are highly under-rated.
These tire pressure settings are great feedback. I'll keep this in mind when I get my set installed. Discount Tire will always revert to the recommended OEM tire pressures unless you tell then something specifically different. I've included below a leaflet from Baurm on the Bravuris 3HM.
Thanks,
