Old Feb 6, 2016 | 11:20 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: Interior Door Pull Handle Repair/Retrofit with Pics
[QUOTE=onehundred80;858651][SIZE=4]I do not think that you would have to take off the inner part, just make room for the stiffener to fit in the channel and screw it down. You certainly do not need to take the chance of making it weaker by breaking it when the object is to make it stronger.
You can see the other ends of the door pull.
I need to remove it so that I can do the CF wrap on the inner section. The kit that I have only does the section you can see but I wanted to do the back side to address the cut finger issue as well as complete the look. Thanks though.
