Old Feb 7, 2016 | 11:01 PM
kingdavid54's Avatar
kingdavid54
Default Re: Crossfire won't start
Originally Posted by BWilson
Well I just got back from the Parts Store having them load test the battery in the Crossfire. The said it did need charging so I had them charge it up. When I got back they said their machine said the battery had 25% of the life left in it. I had never heard of that but it was 3 yrs old so I went ahead and replace it. I installed it but haven't hooked it up waiting on the new Bosch CPS. When I get it installed, then we will hook up the battery and try to crank it again.
Now you see why I was asking you the series of questions pertaining to the battery , the series of events that you described was pointing to your battery. Don't throw away the original CPS because there was probably nothing wrong with it. You can use it as a backup, if you still have the other CPS installed I would go ahead and clean the battery terminals install the new battery hook it up make sure you tighten the battery terminals so that you cannot move the terminals on the post, then put your key in the ignition turn it to on / run position but don't start it, that way the security system will resync itself, give it a full minute or two then try and start the car, if the car starts and runs you've hit a home run and you're good to go if it starts but shuts off turn the key all the way to the left and then turn it back to the run position and let it resync itself again and then try and start it again. Good luck hope it works for you.
