Old Feb 10, 2016 | 04:40 PM
onehundred80
Default Re: Looking for SRT 6 Air Pump
Originally Posted by 4406bbl
That would correct sir. If you are aware of another way, please advise. I wish I could just chunk it; but the Great State of NC won't allow it to pass inspection w/o having the "$800.00 fancy hair-dryer" in good working order.
You look at the relay in the RCM and fix that, it is the most likely source of the problem. First though you should tell us the symptoms, that would help a lot. The problem could just be from a poor ground or to a relay in the RCM with burnt contacts.
