Old Feb 11, 2016 | 12:18 AM
cuziamninja's Avatar
cuziamninja
Default Re: 05 won't Start. Suspecting Skreem?
Originally Posted by Speedy4x4
Sounds like the Skreem issue.
Do you have more than one key?
Lookup resyncing the key, I can't remember how, worked for me, changed battery in fob, resync key and another battery unhook, fired right up and not a problem since.
There are others here that will chime in, with suggestions, stealership will just make you waste thousands literally.
Ill give that a try tomorrow. I might have already done it, with the two button trick.
Doesn't the Skreem module need to be repaired at the dealer? Or is that possible to fix yourself?
