Old Feb 12, 2016 | 03:13 AM
srt6Master's Avatar
srt6Master
Default Re: coolant overflow tank leak/supercooler leak
Sorry to hi-jack this thread but I have a major coolant issue. My car does not leak coolant unless in high boost, I can run the car all day but when I get on it the coolant will spray out of pressure gauge of my Needswing supersooler.
We have pressure tested the block, checked the head gaskets, and looked for other leaks(Everything came back fine). We put a more heavy duty pressure gauge on the supercooler which did not work, we measured 22psi out of the supercooler/heat exchanger once in high boost and coolant begins to spray.
We also bypassed the intercooler to see if there were any air leaks bringing more air into the system under high psi, but coolant still sprayed immediately once flooring the gas pedal bring the supercharger in high boost again.
Any ideas would be greatly appreciated. Thank you
